hello I already have purchased some solid oak flooring, 90mm wide
I have also purchased Elka 3 in 1 Lay (Dpm/acoustic/adhesive. I already have these.
The floor is solid concrete, with a little bit of residue (from old parquet, hence why I chose the 3in1)
There are a few areas, around a metre square x 2 that need to be levelled, I want a water based, and something that can be feathered out.
It also needs to be purchased locally, I have toolstation, screwfix, topps and tile giant locally(I’m in Rayleigh, Essex)
I’ve seen
MAPEI ULTIMATE LEVELLER 1210
https://www.screwfix.com/p/mapei-ultimate-leveller-1210-self-levelling-floor-compound-20kg/4377v
It’s says heavy use, and down to 1mm feather, remember I’m using the adhesive on a roll (I’ve already purchased) would the above be ok, and can be purchased locally with a primer.
Kind regards, (keep safe everyone, in these times.)
I’ve seen
