    Dismiss Notice
Laying Underfloor heating Pipes
Discussion in 'Plumbing and Central Heating' started by Taliz, 19 Oct 2011.
  1. Taliz
    Taliz
    26 Nov 2010
    21
    Thanks Received:
    Yorkshire
    Country:
    I am laying underfloor heating pipes, followed by a sand and cemend screed.
    I have read that the pipes need to be under pressure whilst the screed is layed and dries.
    Is this really nesessary. There are no joints under the screed. I will heat the floor up fully and allow to cool before tiling to get any possible cracking out of the way.
    I cannot connect the pipes to the manifoild as the walls are not plastered and there is no roof on the extension yet.
  2. Sponsored Links
  3. DeltaT2
    DeltaT2
    24 Aug 2011
    1,400
    Thanks Received:
    165
    Glasgow
    Country:
    Most put a board on the wall mate & connect the manifold/pipes etc. This will permit you to test as required. And a test is required, this not only ensures all the pipes are water tight, but if you leave it on test, and a pipe gets damaged you'll know right away.
    You don't want cracks in any concrete containing pipes mate, two concrete surfaces moving will bust the pipes!!
  4. Taliz
    Taliz
    26 Nov 2010
    21
    Thanks Received:
    Yorkshire
    Country:
    Thanks for the reply.
    Have ordered the manifold so I can connect it all up before screeding.
    Cheers
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
