ldv hightop roof leaks
23 Sep 2012
Hertfordshire
can anyone help is the roof seal for ldv hightop under the squarish strip that runs in the gutter secured by two large screws one each end and are they screws or bolts as I dont want to remove these and hear a rattle from inside .I cant check inside as I put the panels and carpet inside while the weather was dry ,have had to drill two holes in the rear corners of floor to let the water flow out and chopped the original ply floor away from corners so my floor does not get wet and where are the roof fan drain tubes ?
