Seems to be directly off the main as both the inside and outside s/cocks fail to stem the flow.
Enters property vertically in an outside dunny bottom left corner. (Couldn't be much closer to the corner).
Pipe rises 2.5" out of the ground, then elbows 90 degrees 2.5" parallel to the side wall. It's somewhat battered...i.e. not perfectly cylindrical. It has a flattened section after; obviously had a hammer taken to it, in an attempt to 'cap' it off.
Even though the pipe is connected directly to the main, I'm told by the Water Board that it's my responsibility as it's on my land...this is true??
Secondly, the WB put me in touch with a plumbing service that initially wanted to charge around £220...when they found out that they didn't have 5 or 6 inches of reasonable quality pipe available, the story changed to over a grand, including tracing, digging and a Highways Notice for the digging....does this sound right??
Thirdly, on hearing the disappointment in my voice when many hundreds of £ were mentioned, the plumber chap suggested that I bash the pipe with a club hammer...back to square one...
Is there an alternative for capping such pipes? Would a normal jobbing plumber take this on and be insured should the worst happen?
