Leading on from drilling tap holes
17 Nov 2005
Down
Having trouble finding a set of taps to suit a friend.
They need a set of taps with a shower head attachment, but the existing taps have had the holes drilled at centres not standard to most sets. (145mm reqd)
Can anyone suggest a solution other than fitting a mixing shower, while sticking to the £200 budget?
Cheers!
could you maybe go for a 4 piece set ? like this....
That would allow you to use the 2 existing holes, and then simply add extra holes for the outlet and handset ?
Well if standard holes are 180, as i think, then the holes at 145 ctrs would be covered by the new taps , as long as it can be sealed to stop water getting under new tap and causing damage it should be ok.
Cheapest option i guess.
