- Joined
- 2 Jan 2015
- Messages
- 4
- Reaction score
- 0
- Country
Hello everyone,
I have a leak behind my washing machine. I noticed it a few weeks ago, but I think I need to get a plumber to fix it as I'm not very good at things like this.
I took a picture. The water inlet pipe has two grey pipes attached to it. Basically, the grey hose at the top goes into my washing machine, and the other grey hose at the bottom goes into my dishwasher.
(Please excuse the messy wall - this is behind my washing machines and I had to pull the bugger out to see this).
The leak is coming from the where the grey top hose connects to the water inlet pipe. You can see a drip on the valve that can turn off the supply to the washing machine. The leak is somewhere around that blue connector. I tried tightening it, but it's fully tightened.
Can someone tell me what those connectors are called, and what I would need to fix it?
As a plumber would probably take advantage of us females, I'd appreciate it if you could tell me the part names and what needs to be done so I can relay it to them and hopefully not sound too dim.
Thank you!
Sharon
Thank you!
Sharon
