Fortunately rare - or so it seems from comments here, but I came across a failed joint yesterday. HTR supplied by 'well-known bath-seller' some years back. Apparently perfect condition but drip from T joint linking bottom rail to vertical tube. Fooled me initially because the slow drip fell straight onto the valve tail immediately below, so it looked like a different problem.
Are failures in HTRs actually quite common?
Is it likely that internal corrosion caused it? (System actually very clean and airtight but this particular HTR IS at the high point of the system, where air (if any) would tend to collect and there WAS evidence of the system being allowed to run with low pressure.......
What's the supplier's attitude going to be? (one previous thread here discussed excuses such as 'too much inhibitor' and 'agressive water', so maybe they're still playing silly games along those lines....)
