Leaking boiler valiant ecotec plus 612 ( help please )
30 Oct 2023
Hi on entering the loft I noticed a small pool of water under the boiler , on looking it’s not leaking from any of the copper pipes I see under the boiler but I see it drip from the edge of the cover at bottom of boiler so must be inside somewhere , there was no pressure I opened refill valve to add a little pressure it then showed pressure in the dial , however it did nothing the screen keeps flashing con I tried turn off and on few times and reset boiler but it just doesn’t do anything any one any idea on issue I just wanna know any info before I call out an engineer tommorow ? Thank you
Yes, the leak should stop after so long of not being used. The Con usually indicates a new pcb, but could be water ingress onto harness/low voltage component.
Is there any usual suspects to look for on the water leak ? And is it something I can try drying out before replace pcb or get a company in ? Cheers for the help
Best getting a company in as removing the cover forms part of the combustion circuit and needs checking, and also they could bring a pcb if that’s the case. As it’s a system boiler, there’s not much inside, so possibly the circulating pump or could be a failed condensate hose (model depending). If the latter, then that could be potentially dangerous too, as products of combustion could escape.
