plz someone help me i recently whilest instaling a new shower tray i acedentlly broke the glued t fitting connected to the soil stack. the t piece was a 4 inch connection that t'd of to a inch and half fitting unfortunatlly it was the inch and half fitting that broke so i cut of the broken peice and drilled a hole in to the t peice to try and resolve the problem with a strap on boss. the boss is now leakng and set fast to the pipe with solvent weld. the biggest pain is the space i have to work with im very hamperd by the amount of space to work with as the pice in qeustion is between to floor joists on the second floor and also as its the stack its away in the corner iv tryed stickinh lots of silicon on it but in one swift swoop all of that came of in one swift pull today as i saw it was still leaking. plz help me is there anything i can do or do i just need to cut and bruise myself trying to cut this pipe and lift it to put a whole new peice in? lmao also running up the stack the mains and hot water pipe and about 6 alarm cables.
oh also the t peice isnt a push fit but is the glued type at both ends
its a big job if i have to replace the walls have been tiled and a vanity unit also hampers my working space
