Hi there,
I have a problem with my Triton bar valve shower first of all leaking, it seems to be an issue with pipework (which i can't get to without smashing a wall down) or the valve. The shower is also stone cold unless i run a cold water tap.
I'm was considering replacing either the flow control valve or thermostatic valve (or both) but i wasn't sure which one to start with to try fix this issue?
i should add that the shower is only 1 year old
