Leaking & Cold shower - which valve?
19 Aug 2009
UK
Hi there,
I have a problem with my Triton bar valve shower first of all leaking, it seems to be an issue with pipework (which i can't get to without smashing a wall down) or the valve. The shower is also stone cold unless i run a cold water tap.
I'm was considering replacing either the flow control valve or thermostatic valve (or both) but i wasn't sure which one to start with to try fix this issue?
i should add that the shower is only 1 year old
I assume that the shower has worked just fine in the past?
I would replace the thermostatic cartridge first, since it seems that the ratio of hot and cold is the issue.
Also, you say it's leaking? If it is leaking in the wall, I would get that sorted regardless of it's position in the wall.
Yeah the shower worked fine previously for 3/4 months.
I'll buy a new thermostatic cartridge, I've had a look on ebay and see wo have generic ones for £40 or an official one from Triton for £90
It been slowly leaking since about 2 months after install but as the plumber did a cash in hand he's not interested. The pipework is behind a door frame and the tiling is near impossible to take off so was looking to see if I can resolve this without demolishing the shower I just paid thousands to have installed :(
next time you might consider a surface-mounted shower so the wall doesn't have to be smashed apart to fix it.
yeah thanks for that response and for your information it is a surface mount however the pipework (if its not the valve) is obviously inside the wall.
That'll teach me
If it's leaking in the wall, you need to fix it - period!
That's the thing I don't want to go taking apart the wall unless i know for a fact that its the pipework leading to the shower if its possible the surface mount shower is failing and pushing water back in to the wall.
