- Joined
- 8 May 2017
- Messages
- 10,684
- Reaction score
- 2,882
- Country
Ask as many questions as you like mate. Bear in mind the toilet pan always remains in place ,so even when you have the cistern off ,a big bucket full of water can be used to manually " flush " by just pouring it into the pan ,if needs be. You mentioned the fill valve was separated when you purchased it ,that's unusual .everyone I have fitted was pre assembled ,and I have fitted loads of them. They are height adjustable ,so they do extend.the little plastic clip secures it once you set the height ,quite Important that. If the two parts can pull apart they surely will when water pressure is applied.
