Hi all,
I recently found a very small leak in the gas inlet/isolator valve to a friends Baxi Bahama 100 boiler along with water leaks both sides of the double check valve in the fill loop and at the boiler's mains water inlet valve.
The water leaks were no problem to fix but the gas leak may be a different matter. A bubble test on the gas inlet/isolator valve shows a leak coming from the threads around the back nut on the inlet side of the valve - like the water inlet and check valve it's probably not been tightened properly.
Ordinarily, if it's a water union, I'd just nip the back nut up some more but as it's on the gas and it's 22mm I'm a little concerned about applying enough force on a spanner to tighten the nut only to find the thread's been crossed or something. Am I right in believing this leak should only be fixed by a Corgi registered engineer or is it something I could do?
Cheers.
Cheers.
