Leaking internal stopcock which is attached to lead pipe
4 Jan 2013
Manchester
Hi all,
I require some advice please. I have an internal stopcock in the kitchen which is leaking slightly and causing an air lock in my property and when my next door neighbour uses their water and turns it off you can hear the pipes bang.
The bottom of the stopcock is attached to a lead pipe which looks like it is bulging.
How can I repair this small leak? I am presuming that this is what is letting in the air as I have had a new washing machine put with a cold only feed and wondered if this would be the cause of the air lock?
Either way the stopcock needs to be fixed but I am unsure how to go about it and whether it would be under United Utilities' remit (I doubt it)?
Any advice greatly appreciated!
Thanks,
Zoe
If it is leaking from the gland nut around the spindle you can unscrew the gland nut wrap ptfe tap around the spindle pack down and screw down.
Any other leaks probably best to replace the valve.
The bulge in the lead is where the plumber has wiped the joint that connects the lead to the stopcock and perfectly normal
I've added photos of the tap
It is leaking where the spindle goes into the main part.
If I unscrew the handle off, will the water just be on full? The water isn't going to spurt anywhere is it?
Zoe
Gently clean away all of that white crud from the spindle area - use a soft wire brush if you have one.
That should reveal the hexagonal gland nut......using an appropriate spanner, try to tighten it a fraction.
If that doesn't help, the nut should be unscrewed, and it will ride up the spindle. If it seems tight, work it to and fro gently. PTFE tape is wrapped clockwise around the spindle, and pushed down into the space left by the nut - it will be compressed more when the gland nut is screwed back in.
You won't get a flood by doing this, maybe a few more drips than normal.
As the others have said, the bulge of the lead is normal.
So, don't heave the stopcock about at all - lead is tougher than you think but needs a professional to repair! Give it an easy time.
Incidentally, air won't get in there - the airlock problem will be somewhere else, I feel.
John :)
