Leaking - LONG PIPE FROM HEAT EXCHANGER Vokera, part no. 10023947
20 Nov 2020
The pipe is leaking and I presume requires a replacement hose / pipe.
I'd like to understand:
1) Will a replacement pipe solve the leaking (The pipe leaks when cold, but no leak when warm)
2) Is the pipe replacement a simple DIY job, or is it best left for a professional ?
3) Any issues / tips to look out for when replacing the hose ?
Note: I've found the two water isolation valves to the pump, which is where the cold and hot flow pipes leave and enter the heat exchanger. I can isolate the electricity to the boiler by just unplugging it.
img_8923_li.105556
img_8923_li.105556
Can' see the pictures but @ianmcd can probably help if you give more information. What boiler is it?
Thanks Ian,
What is the indicator that the system is dirty ? The boiler was serviced ~ a year ago.
Thanks Ian,
feel the hoses they will be hard and brittle, but dont squeeze them as they will deposit all the crud into the hydraulic manifold and a total mare to get out , servicing the boiler , the water quality would never be checked , unless it was BG trying to sell you a powerflush
