- Joined
- 12 Aug 2006
- Messages
- 41
- Reaction score
- 0
- Country
I've just discovered that 1 of the miniature valves on the pipe leading to the kitchen rad is leaking - from the thread. What can be done as a temporary remedy? Anyone?
Eh? A radiator valve allows you to replace a radiator - there's no need for any additional valve.Monkeysoon said:I am referring to the 'latter' - the valve that allows you to replace a rad easily.
It won't, but I would call the part that houses the spindle a "thread".The leak is coming out of the thread - the bit you turn with a screwdriver, so I don't see how 'nipping' the nut will help?
I very much doubt that it's the same, because the pictured one is a tap connector combined with spherical valve.Monkeysoon said:Yes its its the same as the one in the picture...
It very much isn't a miniature valve....a miniature valve.
Yes.The leak is coming from the spindle/thread and shows no sign of abating. Is replacing the thing my only option?
In that case don't attempt to freeze it. Bunging is an option though.I don't profess to be particularly proficient at plumbing.
Are you saying that both parts of the pipework are captured and that you won't be able to withdraw either from the valve? If so then you'll need to drain down and remove the pipe from the radiator valve to release it.How easy will this be, bearing in mind copper pipe isnt exactly..flexible?
The valve you've got is superfluous to your needs. Frankly, I'd remove it permanently. If you really want to have a valve there, then fit a top quality full-bore spherical valve, such a lever ball valve. You can always remove the lever to make it look prettier.I thought these things were supposed to make things easier!![]()
