LEAKING NEW FLUIDMASTER 400 BOTTOM ENTRY FROM PLASTIC CISTERN NUT.
26 Sep 2012
London
Hi
If anyone can give me any advise on how to stop a leak please ?
I have just installed a new Fluidmaster 400 float valve bottom entry brass shank.
It is now leaking with a drip from the bottom white plastic washer which fits onto the cistern.
I made sure the rubber washer was put on cone end facing down inside the cistern but maybe I tightened it too much, worried about untightening now in case leak become worse.
Not sure what to do now, do I remove it and start again, says hand tighten nut in instructions , I used a wrench and maybe tightened too much, would this of damaged rubber washer ? do I need to buy another valve ? Would sealant help ?
Thanks for any help please
Read more: https://www.diynot.com/diy/threads/leak-from-new-fluidmaster-400.573283/#ixzz6yV1XcFf1
26 Sep 2012
London
will try that tonight, but will that make a difference, could I of overtighned the plastic nut
26 Sep 2012
London
Thanks for the info, the leak is dripping down the brass shank from the plastic washer.
