- Joined
- 27 Oct 2020
- Messages
- 44
- Reaction score
- 4
- Country
Hi, I have a very slow leak coming from the shaft of the tap on my stopcock (1 below), where the shaft enters the body of the stopcock - see photo below. This only happens when the tap is open, when it's closed, the leak stops.
Can I (after turning off the mains water at the stopcock outside my property) unscrew the nut that the tap goes into (2), to see if I can clean the inside? Or should I unscrew nut (3)? This is a twenty year old stopcock that I fitted myself many years ago, when I was building a new kitchen. The water supply pipe that comes up from below is black and flexible, and it was a non standard width, imperial I think, not metric, because it was from 1980, when my house was built. Does anybody know what that standard width was back then? I remember having to shop around before I could find a stopcock that would fit it, because it wasn't metric. If I can find that out, I can just replace the whole stopcock, but I thought it might be quicker and easier to unscrew the part where the tap goes in and see if there is a build up of limescale inside.
