Leaking Tap Pipework - What Do I Need To Replace
4 Jan 2006
Devon
Hi;
I have discovered a leak under the sink, on investigation it looks like there has been a slow leak in one of the tap connections for a while (its badly rusted) but must have just got work with additional use.
I remember the plumber having a lot of trouble fitting these connectors as they are very tricky so I am not looking forward to replacing them?
What kind of flexi pipes do i need? where can i get them from? and is there an easy way to fit them - i.e. do i need any special tools?
I hope the Tap itself is OK as it was about £120!!
I'll tweak the connector where the flexible pipe meets the copper pipe but I don't think that is the problem.
The kitchen was fitted several years ago but as we have been working / living away, has only been used for a couple of months a year.
Pics:
You have to take the old ones off first because the thread into the tap body may not always be the same. Some are even factory fitted and don't come off!
Also the connections to the copper vary although it looks like yours are 15mm compression
Below are links to similar to show you at least two variations
10mm threads to a tap body
http://www.screwfix.com/p/flexible-tap-tails-10mm-x-15mm-x-300mm-pack-of-2/27936?
12mm threads to a tap body
http://www.screwfix.com/p/wras-hose-m12-15mm-x-300mm-x-8mm-pk2/57875
Edit: Drat - Same as above post ! At least the OP has two places for shopping.
That looks like a Franke tap so hopefully should be ok. I would imagine the reason the plumber had trouble fitting it originally is because the sink is sited on top of two separate units instead of one double unit, resulting in part of the carcass being cut away. re-fitting shouldn't be so bad but might be easier to remove the tap first before replacing the flexis. When the new flexis are on you can normally push each flexi through the hole one at a time.
He didn't have trouble fitting the tap, he had trouble tightening up the flexi connector at the tap end. The connections are up inside the base of the tap and he couldn't tighten them up sufficiently - they kept leaking :-(
Just found this link which kind of answers my question:
http://www.diynot.com/forums/viewtopic.php?t=219657
Is ballofix a particular type an as asked above what's the difference with isolators advertised as full bore?
Is there a special tool needed to do up the tap end of the flexi pipes seems too small to get a spanner in the tap block!!!
Full bore has a bigger hole in the centre, if you have a hot water cylinder then fit full bore.
1. Turn off water mains (main stopcock)
2. Open cold tap in bath and wait until water stops running
3. Open hot tap in bath to let the rest of the water out.
4. Open any other taps downstairs and wait for all water to stop.
5. Remove flexible tap connectors from pipework and remove tap.
6. Fit new tails to tap and fit tap to sink
7. Fit isolation valves to pipe work and fit tails to isolation valves.
8. Turn isolation vales to the off position and turn on water main.
9 Fit system remove air check for leaks
10. Turn on isolation valves (check tap is not leaking)
11. Job done, Pat on the back from the boss!
This is how I do a tap change when there are no isolation valves under the sink on a gravity system. I don't touch the gate valves in air-in cupboard as they normally leak or get stuck.
If you have a combi or unvented then just turn off the mains and drain down
Andy
Andy
Many thanks - your a star
The word ballofix is used as a generic term for isolating/service valves - like hoover for vacuum cleaners.
Ballofix (upper case 'B') is a brand name of Pegler Yorkshire. Pegler Yorkshire Ballofix valves are not full bore.
Full bore valves will give a better flow rate.
Might have to shorten the copper pipe that the Flexi connects to to get a smoother curve?
Aha;
Just emptied out the sink cupboard and found that the plumber had already fitted Isolators on both the hot and the cold. He has fitted them to the origanal supply pipes and then fitted a length of copper pipe to the Flexis so I don't need to fit Isolators.
The leak does not appear to be constant and may only get worse when the tap is used? I'll replace the Flexi coupling but if that doesn't do the trick could the tap itself be at fault?
