Got a problem with my problematic old Worcester 240 combi. I woke up in the night to hear a drip drip dripping from the boiler cupboard.
It was leaking out of the bottom of the boiler so I took the cover off and found that the source of the leak was from the inside.
You see that pipe, the water is coming from the left, where it enters the gas flame bit (I don't know what it's called!), running down the pipe and dripping from the lowest point into the boiler. Where the water is dripping onto is the timer an electronic stuff but the boiler still seemed to have power. Anyhow, I switched it off at the mains to prevent further electrical damage but now need to know what the problem is.
I figured the leak is either the water in the system or from the mains that passes through to be heated (although there was no hot ater being sed at the time I guess it has standing water in it when the hot tap is turned off).
I drained the CH system from the lowest radiator and now the leaking has stopped so I'm guessing it's something to do with the water in the system rather than the mains supply.
Any ideas of what it could be and where I can start looking?
Cheers in advance for any help. Hopefully it ain't terminal because as much as I want a new boiler, I can't afford one just yet.
Regards
Fred
Regards
Fred
