Leaky atrium door help
15 Jun 2011
Minnesota
Our atrium door (on upper deck) appears to be somehow/somewhere leaking to floor below. Water is pooling within the wood frame surrounding a large 3-window casement window. Water is not directly in the actual window frame, but the frame beyond that which is directly over the window sill, if this is making any sense. Help. I so hope I don't need to remove the door and upper siding.
Appreciate any help/thoughts.
Even though they call them exterior doors they are not!
The glass is not sealed from rain from the outside. It leaks into the plastic fitting holding the glass and into the inside of the door causing damage that is virtually impossible to repair without replacing the doors.
Removing the plastic housing removes the glass.
THIS IS NOT AN EXTERIOR DOOR!
