I'm using chrome plated pipe and compression fittings inside a kitchen cabinet and am finding it very difficult getting rid of leaks. It's 15mm pipework and I'm turning 4-5 flats, which has worked fine for me in the past on ordinary copper. Where there's a leak I will undo it, put plenty of boss white round the back of the olive and tighten it up hard again. Sometimes the leak goes, sometimes it's very minor but still there and I try again. It's all a bit iffy and I'm concerned it might come back again when the kitchen is finished.
The problem pipe run is at mains pressure. With pipework at lower pressures I have no problem. Is there something I should know about chrome - like don't use it in mains pipework? I haven't taken any special steps like removing the plating at the joint, something I know you have to do for soldered and push fit fittings. Is it OK to use it with the plating under the olive? I don't want to overtighten but maybe I'm not tightening hard enough. Anything else?
