Our electric shower broke, so i've replace the unit with almost identical unit. The problem is that now i've installed one of the joints is still a bit wet, a droplet forms every minute - so its not a running leak or a major problem - but i want to sort it, to stop future issues or wasting water.
To give you an idea - the copper feed pipe comes out of the wall, which has the original olive and nut on it. I have now attached the new shower to the feed pipe via a female elbow joint (I believe this is the right name).
Its the joint for the feed pipe to the elbow thats a bit drippy. I was thinking of just using some FTPE tape on the thread, but would that sort it? Maybe the olive needs repositioning? The nut is as tight as it will go, by the way.
Any advice would be apprecaited.
Guy
Guy
