Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a mixer tap on my bath,it has been leaking and is getting worse.I dont know how to change the washer and how do I know which washer to change,is it in the tap itself or in the main body of the mixer?...
Thanks for your reply.The tap is a mixer tap with a shower attachment.It has the standard fawcett style taps that you find on everything.It has a lever to switch between shower or bath tap.The tap was drip, drip, dripping and I was turning the tap tighter each time to turn it off, but now there is a constant trickle which seems to get worse the tighter I turn the tap...
Ok so the water supply is not an issue you can turn off the main and the boiler and empty whats in the pipes out of the various taps.
To replace a washer remove the tap handle, and you will see the mechanism, unscrew the tap mechanism anti clockwise, once the tap mechanism is out you will see which washer needs replacing.
This may not cure the drip as you may have a worn 'seat' and this will need to be ground with a Tap Reseating Tool.
