- Joined
- 11 Dec 2019
- Messages
- 2
- Reaction score
- 0
- Country
Can somebody help me understand what my dimmer is capable of please?
I've recently ordered an aurora aone 250w smart dimmer (because I'm tired of my smart bulbs becoming inaccessible when people flick the switch, so this way I just use normal dimmable bulbs).
The minimum load is 10w, the maximum 250w.
From what I've understood when it comes to halogen bulbs there should be no issues (obviously as long as the total load is less than 250w, although apparently ideally less by 30% to account for the start up load?).
However I'd prefer to use LED bulbs from now on (currently it's a 1 bulb fixture). If I buy a 10w dimmable LED bulb should that work?
To be honest I've forgotten my school electrics knowledge so from what I understand dimmers work by varying the voltage, but I have no idea how or if that affects the wattage, so my thoughts are along the lines of can a 20w bulb only be dimmed by half if the minimum load is 10w, and a 10w bulb not dimmed at all?
The other thing is I've read 2 similar but slightly different bits of information regarding maximum load using LEDs. One states that because they have a high start up load you should assume each fixture will use 100w (even if I used 4 x 5w bulbs?), the other states you should divide the maximum load by 10.
So I'm now confused by how many LED bulbs I can use, and at what wattage.
