I am planning on fitting some LED downlights.
I have looked at some off the shelf kits which come with the transformer and a ready made wiring 'loom' with quick fit connectors on the end. My issue is that the cable lengths between the LED lamps are set and not applicable for what I want to do. Therefore I plan to buy the transformer and lamps seperate and make up my own 12v lighting.
What cable is suitable? Longest run from the transformer would be 3m. I realise that if you go too long that you can get issues with the electronic transformers, but I think 3m will be ok?
Are there any quick fit connectors that I can buy to make fitting of the lamps to the wiring nice and easy - like with the ones you buy already made up. I was thinking Wago connectors, but I am expecting that something like a 0.75mm flex will be the right cable - will Wagos accept a flex like this? I know they will on the lamp side of the connector, but would they on the loop in-loop out side where you normally push in the solid conductor?
