LED mirror via extractor fan
27 Dec 2023
Is it considered ok if before the extractor fan in a bathroom but after the isolation switch for the fan, I put into 4 terminal 20amp junction box, use the earth neutral and permanent live to connect to a bathroom led mirror and then also wire in the fan into the same junction box which would use same connections plus switched live?
This should also mean if I want to turn off the mirror I can use the fan isolation switch as well.
Any problems in this? All circuits are rcd protected on the cu.
Seems ok to me, alternatively could you wire into the mirror light then out to the fan, doing away with the J box.
The mirror light must be fitted in the Zone its designed for
Fan isolator switch is above door
fan is in the loft as an inline fan
led mirror wire goes vertically straight up to loft, so thats where i will put junction box.
