led on the outside
25 Mar 2010
London
please will somebody give me an answer to the question below as i go and see the dg company today to give them the final payment.
Is the led effect work (pressed adhesive backed) on PVC double glazing units done on the outside glass leaving the led work exposed.
For some reaon i thought this wold be done in between both pieces of glass.
Many thanks.
14 Jan 2010
I'm dealing with a project now and it's applied on top.
I'm pretty sure you can buy window units with the lead inbetween... but obviously at a higher cost.
14 Jan 2010
You can also have the lead applied internally, as well as externally.
1 Dec 2009
South Yorkshire
Barbados
Yes, with d/glazing the lead is stuck on the the outer pane of glass, it should even be stuck on within the cavity of the dg unit to cover the glue from the outer lead, if they haven't done in the cavity then the glass shop are real cheap skates, complain to the dg company if this is the case
