We've just replaced a very ancient halogen security light with a LED version.
The light is on the side of a shed, the shed is wired with a small ring main connected to a 'garage' CU and the old light (which had a plug) was plugged into a 13amp socket (inside the shed) on the ring main.
If we ever needed to isolate the light, we just switched off the socket and pulled the plug out.
The cable on the new light doesn't have a plug, simple enough to fit of course but I've been wondering, is there actually any point in having a plug at all ? I have a 13amp DP switched FCU knocking around so was wondering about swapping the socket face plate for an FCU and wiring the light directly into it.
Can I put an FCU into a ring main and have two runs of cable connected to the source side (coming in and then out) ?
I've had a quick look online but whenever FCU's get mentioned, it's always when people are creating spurs (so there's only ever one cable on the source side) and I don't want/need to do that ?
Thanks for your help.
