LED replacement for G4 bulbs
2 Aug 2007
Hi All,
I have some G4 halogen light bulbs in some kitchen under-cabinet light fittings. The bulbs are not dimmable.
The light fittings are powered via 240V to 12V transformers.
I am looking to replace the G4 halogen light bulbs (which are 30mm long) with LED alternatives but have found that the LED alternatives currently available are considerably larger in length (around 40mm) than the existing G4 halogen bulbs meaning the LED alternatives will not fit in the under-cabinet light fittings.
I would be very appreciative if anyone could advise whether the term 'G4' is an out of date term and whether I should be adjusting my search to use a different term which will result in LED bulbs which will perhaps fit in the under-cabinet light fittings
Many thanks
Paul
'G4 DISC' may get you more appropriate replacements. You will need to remove the existing reflector, and probably replace the power supply with one designed for 12V LEDs.
Probably easier to just buy new light fittings.
