Hi guys
I'm currently converting an old outbuilding into a usable room. The room has a step and I'd like to bring the floor level and get some 50mm insulation boards installed. The room is 6m x 5m, with the step roughly at the middle, around 15cm.
I was thinking of using c16 45 x 195mm, with OSB boards on top of the lower side, and 45 x 70mm on the upper side of the room.
However that will still leave a step of around 3cm.
I'm basing it on what c16 sizes I can see on the Wickes website.
Could anyone advise if the above is structurally sound, and if cutting the timbers down by 3cm is the right solution to even it up, or if I should shim up instead of cutting down?
Cheers
Cheers
