I've had a read through the sticky but don't feel like leveling compound is my best option, or at least, its certainly not the cheapest.
I've got a conservatory floor with a concrete slab that is tiled on top. You can feel underfoot the levels are all over the place. We had to take a digger through it when doing the garden and it dropped down slightly but it was never great before.
I've put screws into the floor to assess the actual variance. There is a high spot in one corner and a low spot in the diagonally opposite corner. The max variance is 52mm. Though most of the variance elsewhere is about 20-30mm. If I were to do it in self leveling compound it'd be at least £400 in compound. I'm wary of putting more weight on it as that is what caused the drop. Are there any other options?
I was thinking maybe 25mm jablite on one side then where the variance is much smaller I could just do the leveling compound on that bit? Worried the jablite may be too thin at 25mm to be walking on. To reduce the high spots I was thinking of removing some tiles. That’ll be 14mm off or so in the high spot.
The plan for the finish is 12mm laminate. This will have 3mm sonic gold underlay.
Cheers
Cheers
