Hi all, just after some advice, I am about to do our kitchen but the back wall is a stud wall that was put up to create the current small internal kitchen layout. As it will be the return for an L shaped unit layout life would be a lot easier if it was square and flat. However it is not. It seems to be a few degrees off square to the brick wall it connects to, but also dips by what I'd estimate is up to around 20mm at one point. As it is only 1820mm wide in total this is quite noticeable and would not only be a bit of a pain but would be unsightly when finished. Is this the sort of thing a plasterer could rectify to get the wall at least flat even if it will be out of square a little? Does anyone have an alternative suggestion?
Thanks in advance.
Thanks in advance.
