Levelling Joists
If you have fixings long enough, fixing down into the original joists (rather than the sisters) would be mechanically more sound.
OK thanks, will bear that in mind. I'm going to try and put cross pieces/noggins perpendicular to the sisters/joists too where height allows to give it more rigidity and to give more fixing points.
Is OSB2 secured with screws the current preference for a subfloor? Here in France it is the median price option with Agglomere (Chipboard) the cheapest and Plywood the most expensive (by far).
Hi
My 1930s house had unlevel floors. They were low at the sides of the room and high in the middle.
I ended up levelling my floor joists by tacking on shim cut from scrap wood. then putting the timber floorboards back in. This gave me a level floor to install over floor underfloor heating boards.
Attached are some photos. This was done about 5 yrs ago and I’m not yet aware of any problems :D (fingers crossed)
Thanks Kenny, but I have already gone down the sistering route due to the room size and the differences in height.
Can anyone offer advice on the subfloor? OSB2, Chipboard or Ply?
P5 chipboard is okay, and more manageable than ply, as well as being cheaper, but glue the edges. I'd never use OSB, but I know some do.
