    Dismiss Notice
Levelling, then insulating existing concrete floor.
Discussion in 'Floors, Stairs and Lofts' started by MrSharpey, 30 Dec 2014.
  1. MrSharpey
    MrSharpey
    30 Dec 2014
    2
    Thanks Received:
    Kent
    Country:
    Looking for some solid advice on the best products to use here please. I have converted a flat of about 70m2, of which 3/4 is suspended above a car park. ALL the floors are concrete, and as the temperature has recently dropped, the cold "wind" that comes off the floor is ridiculous! :cry:
    I've done a fair bit of time on Google, but decided to put it to the more experienced.
    The floors are all over the place, where walls have been removed and rooms combined, so this needs addressing first.
    Task list:
    1. Level floors - what's best the use? I've read conflictin reports about what products are best. Some can be affected by dampness. I've not experienced any damp though.
    2. Insulate floors - I don't want to lose too much room height here, so I was looking at plastic sheet (on levelled floor) -> insulating board Kingspan 25mm -> plastic sheet -> 9mm hardwood. Intention is to put Amtico tiles throughout, so that the floor never needs attending to again.
    I know this is a lot at once for a first ever post, but happy to split if need be.
    Thanks in advance!
  2. Sponsored Links
  3. dazlight
    dazlight
    6 Apr 2012
    1,692
    Thanks Received:
    280
    Merseyside
    Country:
    Is the concrete finished now? With a DPM under it?
    If so you could get level using a screeding compound like f.ball1200 then use jumpax which is a good product for keeping Amtico warm to the feet.
  4. MrSharpey
    MrSharpey
    30 Dec 2014
    2
    Thanks Received:
    Kent
    Country:
    Thanks for the reply, I'll look those products up. I've no idea if the floor has any DPM whatsoever. So I suppose I've answered my own question there :) Probably wise to use some anyway.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
