To be honest its no different to a power cut really, and most things spring back to life ok.
However when things go tits up or dont work after, the blame will fall on you, including accusations that the thing should be shut down in a certain way.
You do here scare stories about doors opening and people stepping into the open shaft but i think thats unlikely without a mechanical failure.
Over the years ive been acused of breaking computers, cctv all sorts of things, just for turning off an mcb accidentally in an unmarked board.
back in the early days it was quite common for a bank worker to lose about half a days work turning off there computer, we would get a rollicking, even though the worker should have regularly saved her work.
Modern lift rooms nowadays only have a little box in them, compared to the past.
weve been to power failures, yet on reinstating power the lift aint come back on, so whether theres any safety features built in, thats not for you to know.
the law requires you to do a risk assesment, so your entitled to ask for a specialist, if lifts are not your field.
You say the buildings unoccupied so the lift people may be happy for you to leave it off at the mains till they attend and check it over.
I would, if turning it off is unavoidable, take the car to the lowest point, as that is the safest.
