- Joined
- 17 Aug 2010
- Messages
- 2,888
- Reaction score
- 506
- Country
It depends. The good ones have a smoothing capacitor. The cheap knockoffs leave the capacitor out for cost saving.Most LED's running on ac flicker at 50 or 100Hz, much more so than fluo's
Watch something like the chuck of a drill get up to speed and slow down under LED light and compare it with incandescent.Yeah bridge rectifier and cap I would have thought.
Can’t see flicker. Just checked.
Sure, but stroboscopic effects are different from visible flicker, since in the former case what one is seeing is a static or slowly moving image - one can therefore see stroboscopic effects with light of a frequency far above the 'flicker fusion threshold' (the frequency above which the human eye cannot perceive flicker, because of 'persistence' of the eye's receptors).Watch something like the chuck of a drill get up to speed and slow down under LED light and compare it with incandescent.
In that case why does the flicker of LED lights cause so much trouble to migraine sufferers?Sure, but stroboscopic effects are different from visible flicker, since in the former case what one is seeing is a static or slowly moving image - one can therefore see stroboscopic effects with light of a frequency far above the 'flicker fusion threshold' (the frequency above which the human eye cannot perceive flicker, because of 'persistence' of the eye's receptors).
Kind Regards, John
I would try to avoid doing it. But alternatives are getting harder.So would Led be dangerous too use over Saws etc, like the old single fluorescent was, back in the day, I recall it was even in the then current regs book .
I think, no more than about 15Hz - just as well given 24/25 fps TV and films.
Dunno. As I wrote ...In that case why does the flicker of LED lights cause so much trouble to migraine sufferers?
See also what I'm about to write in response to rsgaz....This leads me ti wonder what actually is the nature of '50Hz flickering' (let alone 100Hz flickering) we keep hearing about people seeing.
You're again essentially talking about stroboscopic effects - which, as I said, have got nothing to do with 'flicker', 'flicker fusion thresholds' or 'persistence of vision'.If you turn quickly or run through an area lit by LED, static objects will flicker or even move.
Yes, that is very easily 'noticeable'. but there are so many 'electronic issues' in terms of getting it onto my screen, that I really don't know what to make of it - other than literally a demonstration of what happens if one tries to display 60Hz (or 30 Hz) 'flicker on a computer screen and then view it.I think the contrast has a lot to do with it. Yes, to perceive motion you don't need many frames per second, but alternating frames of black and white at 60fps is easily noticeable. (your PC and/or monitor may totally ruin this though! My laptop displays at 60Hz) ... I guess that 60fps alternating frames should be called a '30Hz flicker', though. Left side of the screen is therefore 30Hz, right side is 15Hz. Make sure you're in full screen or manually set it to 1080p60.
Quite so - in fact, for most people, the threshold (dictated by the 'rod' receptors') is, I think, no more than about 15Hz - just as well given 24/25 fps TV and films. This leads me ti wonder what actually is the nature of '50Hz flickering' (let alone 100Hz flickering) we keep hearing about people seeing.
Kind Regards, John
I think you're right, but, to confuse things, that seems almost back to front - since central ('frontal') vision majors on 'cone' receptors, which have a much higher flicker fusion frequency (if I recall, around 40-50 Hz) than the 'rod' receptors which predominate in terms of peripheral vision (around 15 Hz, if I recall correctly).Your frontal vision is much less affected by flicker, your peripheral vision much more so, if you "look" at an old crt TV for instance our of the corner of your eye you are more likely to see it flicker.
