- Joined
- 6 Nov 2023
- Messages
- 3,632
- Reaction score
- 1,085
- Country
Nothing wrong with that.It could be, but as I said earlier, with only a red, blue and yellow wire into both ceiling switches, we seem to be missing something!
No nothing wrong with that, if the red, blue and yellow were coming from different cables.Nothing wrong with that.
Does it?It appears in both pictures that the red, blue and yellow are coming from the same cable
Well, shall we ask the OP?Does it?
Yes agreed, this version often pops up too using a 4 terminal junction box with the earths joined together using a terminal block, either inside the juntion box or around the outside.Well, shall we ask the OP?
@weehoose , is it possible to see if the red, yellow and blue wires come from the same cables, at both switches?
I'm going for a circuit arrangement like...
Really ?Unfortunately I can't get into the ceiling void at the moment. I would need to cut a hole in the plasterboard in the ceiling. Could it be as simple as a lose wire in the junction box? I think the previous owners were keen DIYers but nothing seems to have been done too great.
I still don't see a cable with red, yellow and blue wires in your last photo.The cable in the second switch goes down the way. I'm guessing to these in the cupboard where the fuse box is.
Yeah, lost count over the decades how many junction boxes I've seen where all the CPCs come back out to a terminal block, or even worse, they're just twisted together...Yes agreed, this version often pops up too using a 4 terminal junction box with the earths joined together using a terminal block, either inside the juntion box or around the outside.View attachment 362524
It's the downstairs so no accessReally ?
You live in a dwelling with a "ceiling void" which cannot be accessed ?
How was the wiring installed, initially?
There should be a "Person Access" Hole (trapdoor) - somewhere.
Would it be possible to confirm...
as this is the hallway I guess the 'ceiling void' is covered with floorboards and carpet or laminate flooring. Pretty much like all standard properties.Really ?
My apologies.as this is the hallway I guess the 'ceiling void' is covered with floorboards and carpet or laminate flooring. Pretty much like all standard properties.
?!?!?Unfortunately I can't get into the ceiling void at the moment. I would need to cut a hole in the plasterboard in the ceiling.
I was the first to mention "ceiling void" in post #12 - I meant it to be ambiguous, as I was not sure whether the hallway was on the ground floor, or first.However,
this was written (by the OP)
Thank you.I was the first to mention "ceiling void" in post #12 - I meant it to be ambiguous, as I was not sure whether the hallway was on the ground floor, or first.
Mentioning a "ceiling void", would cover both scenarios, as in the space, hole, or cavity above the ceiling.
Cutting a hole in the plasterboard, would be an adequate way to reach a junction box within the ceiling void - I think there may be something lost in translation!![]()
