Is it possible and safe to wire a light fitting via 3 core cable/T&E to a switched plug?
And if so, can you also wire a second light fitting in parallel to the first and run them both from one plug safely?
Just had down lights installed in own extension I've been left with two light fittings and want to use them in the garage where the lighting is poor at best.
( the plug: http://cpc.farnell.com/jsp/search/productdetail.jsp?SKU=PL1003713 )
and these are the fittings in question:
Any help is greatly appreciated!
