Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a new light fitting with 3 terminals - live/nuetral/earth. Basically where do I put the switch wire? In all other fittings I have installed there is a 4th terminal.
Newer installations the core colour will be different:
Red=Brown (live/line)
Black=Blue (neutral)
Black sleeved Red=Blue sleeved Red (switch live)
Green/Yellow=Ditto (CPC/Earth)
Some fittings supply a spare terminal for the looped in line/live, unfortunately some don't. So in that case the line/live will require a connector to terminate the cable together.
