Light switch - Earth wire
29 Sep 2006
London
I've got a light switch (without earth terminal) on a plastic (drywall) mounting box, which also has no earth terminal. Is it OK to connect the earth cable to a single connector, connected to nothing?
Assuming the light switch isn't a metal one (i.e. it definitely doesn't need an earth terminal), then yes, putting the CPC (earth) in a bit of choc block is absolutely fine...
Thanks, I assumed so, just wanted to double check. Both mounting box and switch are plastic.
this cable is called by many earth but earth is what we walk about on.
The cables real name is circuit protective conductor aka cpc.
