light switch L1 and L2 positions reversed
25 Oct 2007
Gloucestershire
hi ,i have just puchased a 1 gang 2 way light switch to replace a dud one with a broken switch on my stairs , the query i have is that on the replacement switch the positions of the L1 and L2 terminals are reversed (etc L2 on new terminal is where L1 is on old and visa versa ) can i wire the switch to the same terminal positions as on the old unit even though L1 and L2 are reversed , hope you can make sense of the question !!!!
Yes - transfer the wires to the same labelled terminals, no matter what their physical layout.
Better electricians wire 2-way lights so that they are off when both switches are either down or up. That means you can be sure that the lights are off when you change a dead lamp.
In your case if the switch is the wrong way up, you can either turn the switch round 180° or you can swap the wires in L1 and L2.
