I posted something last night regarding a junction box I replaced without noting the wiring. I've been out and bought a mains test screwdriver and can now state categorically which wires are live and which are not.
Have as follows - 3 cables which I will call 1, 2 & 3. 1, must be coming from power source as this is the only red wire that mains tester showed as being "live".
I connected this live red to the reds of 2 & 3, one of which must be the switch and one must go on to the next light. Once I did this the black wire of cable 3 became "live" immediately and the black wire of cable 2 became live when I flicked the switch.
I assume therefore that cable 2 is the switch cable and cable 3 goes on to next light.
I then connect the blacks of 1 & 3 together and connect them to the neutral wire of the new light. I take the black from the switch and connect that to the live wire of new light.
The light nearest the junction box stays off and the remaining three are on permanently, the switch, whether off or on makes no diference to any of the lights.
I am confused as really thought the above should work. I do recall that when I took old junction box off, two of the reds were connected together and the third was seperate from them (can't recall where it was connected).
Has the electrician who did my extension put a switch on the negative side of the circuit? Is this why I cannot get to work? How do I wire up as he had, so that at least the lights go off and on. If I can get this far and he has done it wrong, I can get a proper electrician in to check it all over and re do, but really want to get the lights back to the way they were before I quit.
Any ideas would be great.
