While in the Loft today I found a Red Cable, with bare Wires, Well Several Actually.... My Horror.....
Traced one back this evening to source, and it run to a Light switch in the Bedroom, but wasnt connected, the earth wire that ran with it was connected to back box tho....
What im wanting to know it the Switch has a single wire in one hole ( I assume thats the feed to bedroom light, as the other Hole has two red wires in it, I assum to be the Mains ring for the lighting??
Please correct me if im wrong...
After some checking of the Light roses, the Nutral ( Black wires seem to run on a loop from Light to light... Is this normal?
In addition could i tap into the black ring (Spur like) coonect the red wire to the Switch and use the EArth and red, and the tap into black wires to add a Light in my loft, ??? Id like this to be a perminant thing... especially As i must check out the Several other Random Red wires up there..... would be easier with a light than a torch....
