lighting circuit 142 volts phase to neutral and earth
16 Feb 2006
Staffordshire
Has anyone come across this problem I have an idea someone may have connected from a strapper any suggestions?
cheers
what are you using to measure this :?:
Martindale voltage testers need to be connected between either phase and earth or phase and neutral to make a circuit to indicate voltage
more info is needed
these are some things i could think of off hand
could be a loose neutral but that would me that the neutral is live
I think that it could be a short circuit in the cable somewhere where the insulation is down
it wont be the strappers of a 2 way lighting circuit because there is no neutral at any of the switches so you could only get voltage across phase and earth
Are you testing between switched live and neutral and is the switch in the on position.Does the light come on at all?
Are you testing the switch live with the lamp removed using a multimeter?
correct me if i am wrong but a reduced volt drop to me would suggest that there is a series connection somewhere any thoughts please anyone?
yes there is does this make a difference the light is controlled from a dimmer which now thinking about it does vary the voltage i believe.
take the switch off, and measure between the permenant live and the earth terminal.
