First off, apologies to the old-hatters here as i know this kind of repeated theme must do your heads in!
I've looked at the sticky but to no avail.
Having just moved in to our new house, i decided (was told) to fit new lounge lights.
There are 2 in the lounge. Having fitted the first - a simple wire swap - i moved to the second. The second rose has 4 wire bundles and unfortunately, the red tape fell off the switch wire as i took it down
The configuration in the lounge is 2 roses, 1 simple on/off switch, 1 dimmer. Also, it would appear on the same circuit, a conservatory light and on/off switch.
Having wired it back together with what i thought was the right switched-black, the on/off switch now does nothing, the dimmer simply brightens one light and dims the other whilst the conservatory light is very dim.
Can anyone help me to find the switch-ed black to enable the switchery to work correctly please...
Thanks in advance,
Chris.
Thanks in advance,
Chris.
