Lighting planner
12 Sep 2013
West Midlands
I have a new workshop nearing completion and i need to plan the lighting. I will be using LED downlighters, but the question is how many do I need? Is there a formula to follow or guidelines to look at?
Many thanks. Rich
If you are having any rotating machinery such as table saw, lathe etc etc then take care to avoid lamps that may create a stroboscopic effect on machinery. This can make a fast rotating saw blade appear to be stationary or just rotating slowly
Many lamps produce what appears to be continuous light but is in reality pulses of light that appear to the human eye as continuous. Some mains powered LED lamps can pulse at 100 pulses per second
In days of old when fluorescent tubes were fitted in workshops it was common practice to have an incandescent lamp close to rotating equipment as the strobe effect from these was almost non existent.
Horrible deep shadows in a workshop???
I much prefer more appropriate lighting in my workshops.
Better off with florrie batten fittings or (if you have the height) large floods. Downlights look pretty but aren't that useful for working under, the other types reduce shadowing with bounce from the walls
As others have said do not use down lights (spot lights) as they are awful to work under and, in my opinion, more of a fashion statement than actual useful lighting.
HF fluorescent battens or LED battens if you must.
+1 I think that is probably the only topic where few (none ?) of us disagreed with BAS :whistle:
They are rubbish, really really rubbish for anything but spot lighting features - and as much good as a chocolate teapot for general work/task lighting. For a garage/workshop, it really is quite hard to beat a few flouro tubes.
