Hi everyone,
I'm jut looking for some advice - not to do work myself, but what to ask an electrician to do.
We're moving to new house (small 3 bed semi), built in 67. It still has the original wiring, and we want to get work done as soon as we move in. It still has 3 old fise wire fuses, and and 2 electricians have been out and checked some of the lights and not all of them are earthed.
One electrician stated it needs a full rewire, costing £3-4k. The second electrician said that the lights need doing, but that the wiring elsewhere should be ok, so lights and a new board should be fine. He even thinks that we could have an additional outside light and electricity to the garage ithout experiencing problems. The property is in a good state of repair, and the deortions are very good - walls all smooth and recently painted. We're replacing all the flooring anyway though. There are also enough plug sockets already, so we dont really need any more fitted, aside from power to the garage.
So, what I would like to know is:
Does the lighting only option sound sensible to you? Is the damage caused from doing just the lights significantly less than doing lights and sockets, or will it have just as much an effect on the walls and still all need redecorating?
Also, is lighting only actually a good option, or is it risky to do this? I dont want a new board fitted, and then for things to trip out all the time once its done - is this likely if the wiring is not changed, or will it more be casued by appliacnes themselves.
Finally, if e decide to get everything else done at a later date, can it be done room by room and will it be easier if the lights and board are already done?
Any advice gratefully received.
Thanks in advance
Thanks in advance
