I need to install a metal light fitting in an upstairs bedroom which wouldn't be a problem as I have changed several so far and fitted the junction boxes, etc. as no scope for ceiling roses.
However this fitting involves more wires than before and I wanted to check the best way to do it and/or any best practice/tips.
There will be 6 cables involved. 4 are the common ones you'd expect :
loop in
loop out
light fitting
switch
however..... the lighting circuit for upstairs also starts here and the previous occupants have also taken cable for a light in the loft.
Where previously I have used 4 terminal junction boxes, should I now use a 6 terminal one and if so is H/D 20A suitable, or is there a better way to do this?
Thanks for any advice or suggestions on the best/safest way to do this.
loop in
loop out
light fitting
switch
