Lights issue
22 Nov 2018
Got Peugeot Expert 2013. The front lights/indicators work OK back msin lights work but only left indicator light works and neither back break lights work also bizarrely the indicator light on dashboard goes on and off really quickly when indicating right but normally when going left. What's going on?
I had damp issues before under mat in footwell in front.
A fast flashing indicator light on the dashboard normally relates to a blown bulb so check/change your offside right indicator bulb first. The brake lights not working might be an unconnected issue.
Check the bulbs first. Also, a bad earth somewhere. Finally, check if break light switch on foot pedal is working as it should.
I'll check that. There is a lot of water under passenger seats foot mat. I am soaking it up with microfiber cloths and bits of wood jammed underneath.
I had water coming in through roof on driver's side before but my mechanic put tjis white stuff (mastic or exterior silicone on the top to stop it on driver's side). Anyone know what he used? I'll put it on other side i guess. See photos my front roof bars were ripped up years ago when my ladder hit a low lying entrance to car park, I guess allowing water to get in.
The stop lamp switch is actually on the pedal box, and not affected by water below the carpets. It's likely to be your problem, look for burning or a stuck plunger.
The sealant looks like any silicone bodge, clean any area with meths before applying it.
John
Stick one of these over the hole? Tiger seal once on is nightmare to get off, supercstrong.
Gonna ho halfords get them to check and change bulbs
